API - fails to get loadcase and loadcombination
klavs
klavs
When trying to extract loadcombinations, my model gets wrong results.
Some loadcases gets the analysis flag IRobotCaseAnalizeType.I_CAT_COMB
and my load combinations just throws this error
"Error HRESULT E_FAIL has been returned from a call to a COM component"
           RobotCaseCollection RCC = (RobotCaseCollection)str.Cases.GetAll();
            RobotCaseCombination loadRecord;
            dictionaryOfLoadCombinations.Clear();
            int caseCounter = 0;
            for (int j = 1; j <= 100000; j++)
                if (str.Cases.Exist(j) == -1)
                    try
                        IRobotCase RC = (IRobotCase)RCC.Get(j);
                        IRobotCaseAnalizeType AT = RC.AnalizeType;
                        if (AT == IRobotCaseAnalizeType.I_CAT_COMB || AT == IRobotCaseAnalizeType.I_CAT_COMB_NONLINEAR)
                            IRobotCaseCombination c = (IRobotCaseCombination)RCC.Get(j);
                            dictionaryOfLoadCombinations.Add(c.Number, new LoadCombinations() { AnalysisType = AT.ToString(), IRobotCombinationType = c.CombinationType });
                        caseCounter += 1;
                        if (RCC.Count == caseCounter)
                            break;
                    catch (Exception ex)
                        caseCounter += 1;
Stephane.kapetanovic
hi @klavs
most of your question is in this topic
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-get-load-combination-properties/m...
best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
klavs
OMG found the error.
Why is this API all ****ed up.
RobotCase.Get() is from 1..n
 Where bars.Get() and nodes.Get() uses the bar and nodes index.
