Spectral and P-Delta
alfredmx
alfredmx
Dear support team,
We are studying P-Delta effects on a bridge pylon. From modal-spectral analysis, we extracted pseudostatic forces for relevant modes, and then made a quadratic combination. Results are in good agreement with modal-spectral analysis. However, when we combine with permanent loads to run P-Delta analysis, quadratic combination for lateral loads is lost, so results don´t seem to be correct. Is there any way to fix this?
We also tried switching modal analysis to modal taking into account static forces, specifying permanent load case, and turning on P-Delta nonlinearity. Results look fine, but we are not sure if this approach is correct.
Romanich
Hi @alfredmx ,
Have you consider the possibility to try Deformator for this task?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
alfredmx
Hello @Romanich,
Looks very interesting. Will it work if model has shell elements?
Romanich
Hi @alfredmx ,
Definitely it will, but don't forget to freeze the mesh.
Roman Zhelezniak
alfredmx
Great!, will give it a try.
