Material Properties (API)
Message 1 of 31
Is there any way to get tabulated data for all of the materials in the Robot database?  I searched in the program files / Robot 2013 but can't find it easily.
Tony
Replies (30)
Message 21 of 31
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
I'm not a SNIP expert but if you use different concrete grades than specified by this code the calculated values of resistance may be not as you expect them to be. Perhaps @Romanich will be able to provide you with the better input on the SNIP principles.
Artur Kosakowski
Message 22 of 31
Romanich
Hi @ledinhchinh0409
I think in your case you have Rb = 13 * 0.9 (gamma b 2) = 11.7 MPa  that approximately equal to 11.5 MPa in the report
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 23 of 31
ledinhchinh0409
Hi. @Romanich
Thank @Romanich for the reply.
But that's the B20 parameter.
Message 24 of 31
Romanich
Xin chào @ledinhchinh0409,
I don't understand the issue:
Message 25 of 31
ledinhchinh0409
Hi @Romanich
Thanks for the quick reply.
I mean: RSA does not update data when calculating reinforcement.
B20 and B22.5 are exactly the same.
Message 26 of 31
Romanich
Hi @ledinhchinh0409,
As you may note there no concrete grade B22.5 in the Robot list:
You have to use existing concrete grades.
Message 27 of 31
ledinhchinh0409
hi.
Thank you @Romanich!
 This definition was not accepted by RSA.
Is there a way I can define B22.5?
Message 28 of 31
Romanich
In the previous posts @Artur.Kosakowski gave you a comprehensive answer regarding this behavior of the Robot.
Message 29 of 31
ledinhchinh0409
Thank you @Romanich for spending time with me.Hi. The solution is acceptable.
Message 30 of 31
Hello @Rafal.Gaweda
I think there is a flaw in the enum IRobotMaterialType.I_MT_ALL
It doesn't work, but I_MT_STEEL does for instance.
Right?
@Rafal.Gaweda wrote:
API, API, API...
Gift for You attached - whole database to Excel.
If you want only concrete materials  :
replace
Set RNA = RobApp.Project.Preferences.Materials.GetAll
by
Set RNA = RobApp.Project.Preferences.Materials.Get(I_MT_CONCRETE)
Message 31 of 31
Nuraan
Hi
Is this screencast available in another format? Flashplayer is retired since last year.
