mass partition in modal analysis < 90%
Message 1 of 8
hi everyone,
i model a industrial structure but the modal analysis only reaches a 73% of participation, can you give me any suggested to increase this valua to 90%
link of model: https://drive.google.com/file/d/1Fzakac2NLJbV2_1t5zLFhAb72FcIeqB3/view?usp=sharing
Replies (7)
Message 2 of 8
Romanich
Hi @Anonymous ,
Try this settings:
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 8
Hi @Romanich
if i use a mass matrix lumped then the total mass decreases from 236 (ton) to 178 (ton). If i keep a mass matrix lumped and add nodes in the concrete columns to increase the total mass the percent of participation modal decreases to approx 70%
Message 4 of 8
Simau
Hi @Anonymous
Using this parameters you'll get 90%
M. Agayr
Message 5 of 8
Hi @Simau
Yes, but if i apply a mass matrix lumped without intermediate nodes, the mas of the analysis decreases a lot (the total weight of the structure is 243205 kg)
and if i add nodes the weight is increased to 243205kg but the % decreases to 71%
Message 6 of 8
Simau
@Anonymous
Mass are taken into account in nodes, so with columns we lose half of columns weight that goes tout support and then not taken into account.
So spliting your columns you'll get much total mass. (the much you split the higher mass you'll get)
Below spliting columns in 5 part you get
M. Agayr
Message 7 of 8
Simau
And if course you need to increase the number of mode in modal analysis to reach 90%.
M. Agayr
Message 8 of 8
ok, my intention was to avoid increase the number of mode for the analysis time (136 mode)
