Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
masonry wals in Robot
6 REPLIES 6
achillesgr
7716 Views, 6 Replies
hi ,
is it posible to desighn masonry walls in robot?
i have concrete slabs with masonry walls . can i desighn this in robot?
thanks
6 REPLIES 6
Rafal.Gaweda
in reply to: achillesgr
I am afraid not,
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Designing-a-Masonry-Wall/m-p/3235056/highlig...
Or in case of only FEM calculations you may apply reduction of the moment of inertia in panel thickness
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Orthotropic-Stiffness-Coefficients-Panel-Ins...
Rafal Gaweda
in reply to: Rafal.Gaweda
Hello.
I'm trying to perform a finite element analysis in structural walls , however , apply when loading the slab , the analysis shows only the cargar distribution into two beams. There would be the possibility of lancar the surface charge and distribute the same by the four walls that support the floor ?
Sorry my english...
Olá.
Estou tentando realizar uma analise de elementos finitos em paredes estruturais, no entanto, quando aplico a carga na laje, a análise mostra somente a distribuição de cargar em duas vigas. Haveria a possibilidade de lancar a carga de superfície e distribuir a mesma pelas quatro alvenarias que dão suporte ao piso?
Rafacascudo
Can you send the model?
Vc pode mandar o modelo?
Rafael Medeiros
in reply to: Rafacascudo
Sent / Enviado
Rafacascudo
That´s because you defined the orthotropy direction of the 4 walls in the Global X direction . For the walls that are on a YZ plane , this direction(Global X) is perpendicular to the wall plane.Those are the walls that show up no results at all!!
You should define the orthotropy direction on Global Z or automatic( it will respect the panel local axis , that in your case have the same the local XY axes directions in common , X on horizontal and Y on vertical direction)
Other than that you have overlapped panels (3 ,23 e 24 )
Isso está ocorrendo pq vc definiu a direção da ortotropia na dir. X global. Para as paredes que estão no plano YZ , esta direção (X global) está perpendiclar ao plano destas paredes. Essas são as paredes que não exibem nenhum resultado!!!
Vc deveria definir a direção da ortotropia na direção Z global ou automático(ela vai respeitar os eixos locais dos painéis , que no seu caso tem os mesmos eixos locais XY em comum , X na horizontal e Y na vertical)
Fora isso vc tem alguns paineis (3 ,23 e 24 )com overlap
Rafael Medeiros
Thanks Rafacascudo, finally works....
