Lower level columns taking smaller loads?
I am modeling a simple frame structure with cross- bracing elements.
When I look at the results for compression force acting on the columns, some of the lower columns are taking less load then the ones above them.
From what I can understand, the cross-bracing seems to be taking loads in the z (gravity) direction. I have tried to release the bracing from z (xxfxxf) but it still seems to be taking some sort of load off the columns.
When i define the braces as tension only element, non-linear solutions are required and therefore I cannot perform an analysis with automatic load combos.
How should columns and cross-braces be modeled to avoid having cross bracing take Z (gravity) loads.
Nick
mustafahesenow
Hi @Anonymous
Can you send us the model please.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
t.sautierr
You can define gap in your bracket in order to allow for some displacement before it stats resisting.
But normally if your cross-bracing is in proportion to the column, the stiffness difference shall make the job and the X will not be over-loaded compared to the column.
