Robot Structural Analysis Forum
Welcome to Autodeskā€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forĀ
Did you mean:Ā
Load transfert from slabs to beam
4 REPLIES 4
Djokaboris
284 Views, 4 Replies
Hi;
Please need some help in this RC model . Why after applying the load on the slab, it doesn't transfert the load to the beam??.
4 REPLIES 4
hi @Djokaboris
The slabs and beams are not at the same level, so the slabs can't transfer anything without being at the same level or having elements to transfer their loads onto the beams.
Best Regards
Djokaboris
in reply to: Djokaboris
Thanks a lot for your timešŸ™
Thanks a lot for your time šŸ™
hi @Djokaboris
even though this is a crude conversion model, it would be a good idea for you to take a look at the attached report.
Best Regards
report deleted
Tags (1)
Technology Administrators
