Hi;
Please need some help in this RC model . Why after applying the load on the slab, it doesn't transfert the load to the beam??.
Solved by Stephane.kapetanovic. Go to Solution.
hi @Djokaboris
The slabs and beams are not at the same level, so the slabs can't transfer anything without being at the same level or having elements to transfer their loads onto the beams.
Best Regards
hi @Djokaboris
even though this is a crude conversion model, it would be a good idea for you to take a look at the attached report.
Best Regards
