Load Input Table - Filter Loads
Good afternoon,
I have a RSA model from a while back and I need to reinput loads.
I would like to edit the values for a number of these basic load cases, however there are lots! I cannot seem to invoke the 'filter' when using the right mouse just to edit values on basic loadcases.
is there a work around?
Cheers
Lee
Rafal.Gaweda
Autodesk Support
Autodesk Support
..in Excel ?
Example:
Rafal Gaweda
Hi Rafal,
I was hoping to be able to filter out and edit individual loadcases in Robot, without other ones being visible:
Can this be done in RSA 16? Can be problematic as once I start to edit, sometimes the cell reverts back to the original value!
Cheers
Lee
Rafal.Gaweda
Autodesk Support
Autodesk Support
It is not possible to filter Loads table on Edit tab by loadcases
Rafal Gaweda
OK thanks Rafal!
I am still having intermittent issues updating the load values. I have tried opening up in repair mode, and when i replace value in table edit mode, the values reverts back to original?
Rafal.Gaweda
Autodesk Support
Autodesk Support
Try the same but on Loads table opened on Geometry layout (not the one on Loads layout)
Rafal Gaweda
