instability 3 floor mesh
ByrnePM
ByrnePM
I am having an issue with an instability type 3 problem on the nodes of my mesh on my composite floor ?
I have attached model below ?
Can anyone see where the issue is coming from?
https://we.tl/zT8qnwUbaT
ByrnePM
Has anyone had a chance to look at this ? Smiley Sad
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to block RX in the definitions of releases (this will remove the instability warning). Then calculate  the model and check MX values for bars with releases and add RX releases (or partial RX release) where needed.
Artur Kosakowski
Refaat
Hi
I don’t see any issue with your model .
Refaat
