List of not supported elements for lateral buckling analysis robot
antonio.lafuente
antonio.lafuente
HI there
Is there a list of not supported elements for lateral buckling analysis robot? How does the software decide for which elements it performs the lateral buckling verification and for which ones not?
Thanks in advance
Antonio
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @antonio.lafuente
Lateral buckling verification is performed while member code check.
You decide if lateral buckling verification will be done while Code check member type definition.
For steel elements in can be checked by
Design >Steel member design - Options> Code parameters> New
for timber members
Design >Timber member design - Options> Code parameters> New
Please refer to the following tutorial
Steel Design - How to build the model and assign design parameters
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Krzysztof Wasik
antonio.lafuente
This is not really the case. Even if you check the box during the design code verification I get a warning message saying that lateral buckling is not supported for some sections.
According to the link below some section are not supported any I wonder which ones they are
https://knowledge.autodesk.com/support/robot-structural-analysis-products/troubleshooting/caas/sfdca...
Cheers
Antonio
Krzysztof_Wasik
Autodesk Support
Autodesk Support
I did not fully understood your question
Lateral buckling verification is not performed for
angles
tube like sections
user defined sections with arbitrary shape
non typical parametric sections (cross)
Compound sections
For all codes it is performed for I, C and T sections.
There are exceptions for some codes. For instance parametric cross is verified according to Pn (polish code) and is not verified according to EN code.
Krzysztof Wasik
antonio.lafuente
HI again
I'm still a bit puzzled by this question. In the beam below, why has the system not performed any member stability checks even when all types of buckling were allowed in the member definition?
Also, what would the difference between checking or not checking the sway option be? When should this be done? Is it just related to the critical load calculated from your buckling analysis?
Thanks in advance
Antonio
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Ad1 no stability check
No lateral buckling check because it is tube section
No buckling check, probably because element is subjected to tension
Ad2
Sway,non-sway option matters for automatic and semi automatic buckling length estimation procedures.
Please refer to the following thread sway,non-sway
Krzysztof Wasik
