linear load not applied to a panel
Dear support,
Would you mind looking at this small model and tell me why I am getting "linear load not applied to a panel" warning?
Model seems to be correct and all lines parallel.
Also is there a way to check a sum of reactions when slab sits on the elastic ground?
http://www.4shared.com/zip/-RP6HnuF/test.html
Sorry,
found the mistake, the load was copied to nowhere by accident.
Could you just advice of how to check the sum or reactions for the slab on elastic ground? (spring proerties added  through the slab properties).
Rafal.Gaweda
Autodesk Support
Autodesk Support
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-sum-of-reactions-for-the-slab-on-elastic...
Rafal Gaweda
