L section beam
L section beam
L section beam
How do l define L section beam in robot structural
Rafacascudo
Geometry/Properties/Sections
Rafael Medeiros
Artur.Kosakowski
Autodesk Support
Autodesk Support
If you mean a user defined one then you need to use the Section Builder module of Robot as this shape is not available directly as a parametric one. You may want to watch the recording of the 8th Robot webinar which will guide you though the whole process.
http://forums.autodesk.com/t5/robot-structural-analysis/robot-structural-analysis-webinars/td-p/5523...
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
