Japanese characters do not display properly
Message 1 of 9
How do you display columns in plan.  I have a sail structure that I am modeling in building.  The columns show in the 3D view but not the plan views.  This seems to be a recent problem that I have not had in the past.
Replies (8)
Message 2 of 9
mustafahesenow
Hi @Anonymous
It displayed correctly in my RSA.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 3 of 9
Thank you for your response.  The columns are still not showing in my RSA and I am not sure why not.
Message 4 of 9
mustafahesenow
Hi  @Anonymous
Define Axis in the bottom and top level of the columns then go to plan and choose that desired bottom or top level you will see them .
If not please let me know.
Mustafa Hesenow
LinkedIn
Message 5 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
Could you make a screen capture showing what you can see and what you would expect to see? Could you explain what is the 'link' between the column view and Japanese characters?
Artur Kosakowski
Message 6 of 9
The supports display but not the columns.
Message 7 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try these steps:
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 8 of 9
Where do I find the DEEP 3D view.  When i click on project 3D view in xy plane the columns show but not when I am just viewing the xy plane
Message 9 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Mind that the actual sections of the columns are small so may be hard to be spotted therefore you may switch on display of their symbols as well.
Artur Kosakowski
