Verification formulas ANSI/AISC 360-10
Message 1 of 16
Could anyone help me with this?
I am struggling with the design of some members according to ANSI/AISC 360-10 because the calc. note says something about LRFD G2-1 equation but when I read G2-1 equation, this indicates something different.
Also I am getting HUGE sections in some members. I got that an IPE600 for a beam is not strength enough due to this Vry/fi*Vny + frvy,mx/0.6*fi*Fyn < 1 First term is ok but i couldnt find the second one in the code. I think frvy,mx is shear stress for torsion. See captures below. I attached the model as well.
Please help me.
Cesar
Replies (15)
Message 2 of 16
mustafahesenow
Hi @Anonymous
This huge shear came because of spike torsion Diagram .
As you can see that this beam supporting the stair case beams  and the connection between the stair beam and this beam assumed as rigid connection .
As you know also the I beam section is weak to resist the torsion .
All what you can do is to reduce the Mx by this 2 proposals .
1- The Deck slab will resist the torsion and wont allow the beam to rotate and this is valid for your case.
2-make release of stair beam on this connection so the force will transfer to the beam only vertical shear no Mx.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 3 of 16
Yes, you are right @mustafahesenow
Sorry for the question but if I choose the option 1- The Deck slab will resist the torsion and wont allow the beam to rotate and this is valid for your case. I understand that you propose to ignore torsion in that member. What could I do to get a correct section for that beam? if I ignore the torsion in RSA, is there any option to do that?
Always appreciate your support my friend!
Message 4 of 16
mustafahesenow
Hi @Anonymous
Yes the is look at attached picture.
Mustafa Hesenow
LinkedIn
Message 5 of 16
My friend you saved my life.
You rock!
Big massive thank you @mustafahesenow
Message 6 of 16
mustafahesenow
Hi @Anonymous
You are very welcome Cesar.
Mustafa Hesenow
LinkedIn
Message 7 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I just wanted to point your attention to the 'correct' use of the functionality @mustafahesenow indicated (thank you for your priceless help for this forum). It is mostly intended for the situation when you have small torsion (or any other internal force type) and it its influence of the section capacity is negligible. If this is not the case ignoring it may not be the best idea and perhaps yup should find out why it is high when it is supposed to be small first. Perhaps using the Rx - Rx partial release with small stiffness value will be worth considering?
Artur Kosakowski
Message 8 of 16
Hi @Artur.Kosakowski
What do you mean with "Rx-Rx partial release with small stiffness value"?
Thanks in advance
Message 9 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I meant a release like this one:
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 10 of 16
I didn't see your answer before.
Sorry for say it but it didn't work 😞 I used rx-rx partial releases exactly as in your picture in the last post.
That doesn't reduce torsion and consequently shear due to torsion.
Message 11 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the model and indicate a sample beam to look at?
Artur Kosakowski
Message 12 of 16
For example: member 48. Model attached
Without releases
With releases
Message 13 of 16
mustafahesenow
Hi @Anonymous
If you want to use the release option . you should release the stair beam not the supporting one. in  My direction .
Mustafa Hesenow
LinkedIn
Message 14 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
To illustrate what @mustafahesenow (thank you) suggested (as the restrains for rotations are introduced by both stairs and beams along the bar 48 length):
Artur Kosakowski
Message 15 of 16
Thank you for answer as well as @mustafahesenow
Sorry for asking but what is the difference between "Bar releases" and "Elastic partial releases"?
Message 16 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Full vs. spring release with rotational stiffness being related to the bar rigidity.
Artur Kosakowski
