It's possible assign forces to isolated nodes?
Message 1 of 12
Hi, I want assign forces to isolated node but when I run the analysis the forces don't act in others RC elements on story.
I want make a seismic analysis by FHE(Force Horizontal Equivalent) method manually. By this reason I just assign the unique forces to a isolated node, whatever, this node in each story od the structure is the mass center.
Any idea is important for me,  thanks.
Replies (11)
Message 2 of 12
Romanich
You have to connect this node with other nodes using rigid links.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 12
Right but if I do it,  that rigid links must be RC elements like beams? and further if I put rigid link to conect it, the stiffness of story change. Then How I can solve it?
Message 4 of 12
Romanich
Try to use Geometry - Additional Attributes  - Rigid Links dialog.
Roman Zhelezniak
Message 5 of 12
Thank you Mr Zhelezniak
Message 6 of 12
I do it and now I have a question, this diaphragm must be blocked in UX, UY and UZ directions or UX and UY only? Because when I defined it blocked in UX nad UY, I have inestability of type 1 on nodes.
Message 7 of 12
Romanich
Try to block UX, UY and UZ directions.
Roman Zhelezniak
Message 8 of 12
How can I show tables with displacements for envelope values only for the MAX and MIN value in each node?
In the below image we can see a table for envelope value for each node (white color cell) but further there is other values that are not the biggest or smallest in the node (gray colour cell).
Then I just want to obtain a table with  white cells values.
Message 9 of 12
Rafacascudo
The 》and《 symbols are max and min values and the other values of that same line are the cocomitants of when that max or min occur.
Rafael Medeiros
Message 10 of 12
That's right but how can I a table with this max and min values just them?
Message 11 of 12
Romanich
Maybe this will help
Or
Roman Zhelezniak
Message 12 of 12
Rafacascudo
Don't exacly know what you are aiming but ,
1- try the "global extremes" tab down below
Or
2- on the envelopes tab , right click , choose "table columms" and select only the displacement/rotation direction you want to show
Rafael Medeiros
