installing Robot 2015
Message 1 of 19
Is 8GB RAM required for installing ARSA 2015? if yes , how can i upgrade 2014 to 2015 and i have only 4GB RAM ?
Best Regards
Replies (18)
Message 2 of 19
StefanoPasquini6790
Hi noradeen,
I have to suggest you to upgrade your RAM. Try to visit www.crucial.com, there is a scan system that check your PC and find the perfect solution for your RAM upgrade.
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 3 of 19
Artur.Kosakowski
Autodesk Support
Autodesk Support
The minimum RAM requirements for Robot 2015 is 8GB.
Artur Kosakowski
Message 4 of 19
Rafal.Gaweda
Autodesk Support
Autodesk Support
Noradeen
My W7 system after starting eats 3,2 GB RAM itself and no user program is run so 4 GB RAM seems to be a little bit small amount.
Rafal Gaweda
Message 5 of 19
Dear sir
i upgraded my PC RAM to 8GB and when i install i get this message ( attached files)
Best Regards
Message 6 of 19
I did what you said and i upgraded to 8 GB but no result .
Message 7 of 19
Rafal.Gaweda
Autodesk Support
Autodesk Support
May I ask you from where you have got , downloaded version 2015?
It is not published yet.
Rafal Gaweda
Message 8 of 19
8 Gb of RAM? Tell me that this is a April's Fool Joke........
Message 9 of 19
Rafal.Gaweda
Autodesk Support
Autodesk Support
This is a MINIMUM.
Rafal Gaweda
Message 10 of 19
Rafal.Gaweda
Autodesk Support
Autodesk Support
BTW - system requirement is W7 SP1, you have W7 only.
Upgrade your windows system.
Rafal Gaweda
Message 11 of 19
So, if i have 4 Gb, will it be possible to install Robot 2015? In Robot 2014 says 8Gb too.... (http://knowledge.autodesk.com/support/robot-structural-analysis-products/troubleshooting/caas/CloudH... i'm running it with 4Gb.
Message 12 of 19
Rafal.Gaweda
Autodesk Support
Autodesk Support
Will be possible to install but it is below minimum requirements so we do not guarantee how this will work and such version will be out of ADSK service.
Rafal Gaweda
Message 13 of 19
Thanks Mr Rafal
May i know how can i upgrade the OS . ? to be suitable for RSA .
regards
Message 14 of 19
Message 15 of 19
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 16 of 19
Message 17 of 19
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 18 of 19
Artur.Kosakowski
Autodesk Support
Autodesk Support
MInd that for Robot 2015 you have to have SP1 for W7 installed. Only 64-bit OS are supported. XP is not supported.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 19 of 19
Hi Rafal , thanks for your help , RSA 2015 Trail version is now installed Robot2015.png
