Hello
i have instability issue in steel frame structure model , it says that there is instability in node 933 while the model does not contain any node with this number ,
thanks
Solved by Krzysztof_Wasik. Go to Solution.
Hi @Hamza.BA
Instability is reported in calculation node, generated for member force. In your model instability has no influence on results.
To remove warning
Regarding instability of type 3
In most cases instability of type 3 can be ignored. Refer to the article Instability of type 3.
