Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Instability issue in node that do not exist
2 REPLIES 2
Hamza.BA
152 Views, 2 Replies
Hello
i have instability issue in steel frame structure model , it says that there is instability in node 933 while the model does not contain any node with this number ,
thanks
2 REPLIES 2
Krzysztof_Wasik
in reply to: Hamza.BA
Hi @Hamza.BA
Instability is reported in calculation node, generated for member force. In your model instability has no influence on results.
To remove warning
  • Open Loads >Load table
  • Change setting for member forces (case 4) from Node to No node (see below)
Regarding instability of type 3
In most cases instability of type 3 can be ignored. Refer to the article  Instability of type 3.
Krzysztof Wasik
Hamza.BA
in reply to: Krzysztof_Wasik
@Krzysztof_Wasik  problem solved thank you
Technology Administrators
