Instabilities and matrix not definate
I'm having difficulty in getting my model working. There are innumerable instabilities and I cant figure out what I'm doing wrong?
I believe that as a result of these instabilities I'm having problems with 'matrix note definate' and subsequent non-convergance.
What am i doing wrong?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
IMHO there are too many releases.
I blocked RX in their definitions and used 10% partial elastic releases for RZ. In addition I blocked RXZ at supports and set Full Newton-Raphson method.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Thank you Artur, I shall have to explore this solution more so I better understand it, but the model certainly works and the results (moments etc.) are very much in line with expectations.
Thank you again.
