Load distribution Problem on Singly Supported Slab
tau_oragami
tau_oragami
Greetings,
I am trying to model a one way spanning deck slab. However the loading is not being distributed correctly in one direction. Instead the load distribution diagram is showing two way distribution.
Any Suggestions. I looked at other posts, but nothing helped.
Regards.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @tau_oragami
Could you attach this model?
Artur Kosakowski
tau_oragami
See File attached.
Rafacascudo
On your calculation model you chose "simplified load distribution". You will get no results from the plate that way. Choose analytical
Rafael Medeiros
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @tau_oragami
You need to have some objects (e.g. fake beams along the supported edges) to distribute loads to:
but as @Rafacascudo already wrote it such load distribution method doesn't look like the right choice for a model as yours.
Artur Kosakowski
