Information about assemblies
Good morning, everyone,
I have a big question about manual calculation in assembly.
Indeed, when I look at the distribution of moments in my spreadsheet, it seems incorrect to me.
I changed the sign of my moment +/- but the distribution is the same. My highest moment starts at the first row of bolts for the + sign, but should be reversed for the - sign, which is not the case.
Please can you inform me, see atttached files
Thank you very much.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the Robot file with the connection and indicate the part of the calculation notes to look at?
Artur Kosakowski
Thank you for your quick answer
You can look at the assembly 26  and reach the shear resistance for assembly
See the attached png files for summary
thank you again
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The row numbering starts with the bolt that is the farthest from the center of rotation rather than from top to bottom as par a connection view.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
