Incorrect Data - Error Nr.5000
適用対象外
9,675件の閲覧回数
21件の返信
メッセージ1/22
適用対象外
During the calculation of a structural model (constitute only by bars elements), when in Buckling Deformation (Analysis Type), I switch off the option Omit case for structure with deformations, an error Nr. 5000 happens, and the calculation process is stopped. This error only happens in this situation, since the model is calculated normally when that option is on.
Is there any way of overpass this error ?
Best regards,
Tarrataca
0 件のいいね
解決済み
9,676件の閲覧回数
21件の返信
返信 (21)
メッセージ2/22
Pawel.Pulak
Autodesk Support
Autodesk Support
Error 5000 generally corresponds to memory problems.
If restarting Robot before running your model does not help please attach your model (compressed to ZIP to reduce its size) to check it in more detail.
Pawel Pulak
Technical Account Specialist
0 件のいいね
メッセージ3/22
Pawel.Pulak
Autodesk Support
Autodesk Support
解決済み
The model was not attached but if it is the same case are reported via reseller then the reason is in using multi-threaded solver for this type of analysis. Please change to Automatic or Sparse in Tools>Job Preferences> Structure analysis
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
メッセージ4/22
jo2ny
I got the same error, I read the discussion above, changed the analysys method to Sparse, and back to Automatic.
When set to Automatic, Robot just crashes. When set to Sparse, i get the 5000 error.
What can I do now?
I attached the model.
Thanks in advance
I'm running Robot x64 on Win 7 x64
Intel Core 2 Quad Q9640 @3.00 GHz
8 Gb Ram
0 件のいいね
メッセージ5/22
Rafal.Gaweda
Autodesk Support
Autodesk Support
Ionut
Change structure type on SHELL ; 3D frame with FEs can not be calculated as FRAME 3D structure.
Rafal Gaweda
メッセージ6/22
jo2ny
Yep, worked!
Thanks again for your swiftness and precission.
Amazing...
0 件のいいね
メッセージ7/22
適用対象外
I recently run an analysis but I've got the same error
I've tried to follow your suggestion above (changing the solver) but the result was still the same. What should I do?
Thanks a lot!
0 件のいいね
メッセージ8/22
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
0 件のいいね
メッセージ9/22
適用対象外
Please download the file via link below because the file is quite big
https://share.arup.com/ExPages/filedownload.cfm?FileID=91481249ku67885300ki40800690eg
Thanks for the help Rafal
Kurniawan
0 件のいいね
メッセージ10/22
Rafal.Gaweda
Autodesk Support
Autodesk Support
I should have been faster:
Rafal Gaweda
0 件のいいね
メッセージ11/22
適用対象外
Hi Rafal,
I've sent to you separately
Kurniawan
0 件のいいね
メッセージ12/22
適用対象外
Hi
I'm working on a steel truss power mast and during the calculation of the structural model Robot gives me also the ERROR Nr. 5000. What am I doing wrong?
Many thanks in advance!
Analysis type settings:
0 件のいいね
メッセージ13/22
Artur.Kosakowski
Autodesk Support
Autodesk Support
Is the nonlinear analysis convergent? Is it the same after you change the solver type?
Artur Kosakowski
0 件のいいね
メッセージ14/22
適用対象外
Nonlinear analysis works fine if not selecting Buckling in the "Change of Analysis Type for Selection of Cases" dialog box. Originally I was using Sparse M solver with MDA when I got the Error Nr. 5000. When changing the solver type to Automatic, Error Nr. 5000 appears again (Seems like Sparse M is used In Automatic as well). By choosing Sparse (without M), after a 20 minute run, I get the results. I also tried Skyline wich runs approximately 5 hours. I got the warning: "Instability (of type 3) detected at node 217 in direction RX". Seems like it is releated to big differences in stiffness of elements. Am I right?
If so, is it correct to choose Sparse as solver and go on with the design?
I'm sending the file separately so You could have a look.
0 件のいいね
メッセージ15/22
Artur.Kosakowski
Autodesk Support
Autodesk Support
We haven't received the file If you checked the cause of the instability and considered it as not having any negative effect on the obtained results then I think it is.
Artur Kosakowski
0 件のいいね
メッセージ16/22
Artur.Kosakowski
Autodesk Support
Autodesk Support
I have made the quick initial check running your model with for case 1 only. There is no instability reported.
Artur Kosakowski
0 件のいいね
メッセージ17/22
demetris.a.d
hello i have followed all the above suggestions but the error still remains.
i will attch the file
0 件のいいね
メッセージ18/22
Artur.Kosakowski
Autodesk Support
Autodesk Support
The values of load are corrupted.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
0 件のいいね
メッセージ19/22
適用対象外
I have been getting the same error.
I have tried the following:
- Changing analysis type to Sparse and Automatic. The error was removed, but even after 200 modes, the mass participation ratio is still at 5% which is not logical for such a structure.
- Tried changing the modal analysis types, but no use.
- Checking for modeling problems.
Compared to a working older & simpler model than the attached, it seems that the modal analysis is not working as expected.
Please advise. Thank you.
0 件のいいね
