- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all.
I am new to Autodesk Robot and this forum. I have been trying to learn the basics of Robot by modelling a simply supported slab and exploring all the different functionalities within Robot, and I have come across a "problem" I can't find a good explanation for. The issue is with regards to the deflection of the slab.
- What is the reason for the massive difference in deflections when I am in the "Slab - provided reinforcement" window using the "Plate and Shell Reinforcement" to display "deflection map" from "FE results" when I am comparing results from "For required reinforcement" and "For provided reinforcement after verification" when the two quantities of reinforcement are more or less equal?
- The same massive difference in deflections can be observed from the "Geometry" window using the "Panel Cuts" dialog box. Displacements in z-direction from the "Detailed tab" is much lower than Deflection from the "SLS" tab.
Also, how can I do calculations from the "Plate and Shell Reinforcement" dialog box from the "Slab - required reinforcement" window, inside the "Slab - provided reinforcement" window?
What is the difference between the calculation mentioned above and the one that is carried out by the "Calculations" dialog box in the "Slab - provided reinforcement" window?
Best regards, and thanks in advance for the help.
