Hi Krzysztof Wasik,
You are right 100%, I have change the bracing to tension only and after 40 min clicking to accept the type 3 instability, the result almost the same.
If I continue with linear analysis, the type of bracing release that I have done (releasing Ry & Rz at beginning & Rx, Ry, Rz at the end) is still correct?
Technical question please, if you look to the rafters (80 & 129 typical), where in the real final project it'll be one piece connected from the main beam up to the wall, but in manner to connect the struts and bracing to it I have split it in the conjunction node. the problem that i have release it to have 0 moment at both ends wall & beam (real connection will be pin with no moment) but in this way I cannot release any more the struts to be pinned pinned and I am getting big deflection.
is this way correct? or I shouldn't split the rafter?
A big Thank You for all your time and effort Wasik.
