incoherent mesh at edges and Isolated nodes have been found...
raveeshvarma4930
raveeshvarma4930
Good afternoon,
In running the attached model, I have the following calculation messages come up:
Incoherent mesh on edges
The thing is, I cannot see these issues when I highlight them in the message box. When I click on the "isolated nodes" warning, approximately 17,000 nodes are highlighted in the Objects Inspector, yet I cannot delete them en masse. I would appreciate any advice that I could receive on this matter. I have attached the relevant model. Thank you, and with best wishes,
Raveesh
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @raveeshvarma4930
As far as I can see you created your analytical model as if it was the real one with the walls defined to the faces of the other as well as with lot of overlapping panels and very small distances between the panel edges. You may want to wat ch the 1st and the 2nd Robot webinar to learn about the recommendations for both creating such models and meshing them from https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-structural-analysis-webinars/td...
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
