Hi all,
I would like to know if there is an option in RSA to add corrosion to bar section.
just for norma section. see attached file. because some times a have to calculate structures with corrosion, which means that all side of the section will decrease with e.g. 1mm.
now i have to draw the reduced section in autocad (time consuming) and use section definition to add this to the user databese.
is there an easier way tho do this?
kind regards.
