Robot API: Load Case Labels
Dear all,
Is there a way to access (modify, read) the load case labels via API? (I'm not referring to the case number, name or nature etc. but label)
Thanks in advance for the help!
Best regards,
Marcell
Romanich
Hi @Anonymous,
I tend to think that is not possible to change/assign labels for load cases using API.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Try  RobotSimpleCase.label
Rafal Gaweda
Hi @Rafal.Gaweda,
Thanks for your answer!
I've actually just found that you can very easily read and modify case and combination labels using RobotSimpleCase.Label or IRobotCaseCombination.Label.
Best regards,
Marcell
1234eddie
Hi @Anonymous @Rafal.Gaweda
you solved this with using API, i'm currently using dynamo with a python script, and try to achieve also to set the labels(because it's annoying that the label is the case name).
this is the API information.
this is my setup which creates the loadcase, only with the case name as label.
This is the python code:
import clr
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
from System import Environment
user = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData)
clr.AddReferenceToFileAndPath(user +r"\Dynamo\Dynamo Core\1.3\packages\Structural Analysis for Dynamo\bin\RSA\Interop.RobotOM.dll")
from RobotOM import *
from System import Object
#The inputs to this node will be stored as a list in the IN variables.
LoadCaseName = IN[0]
LoadCaseNumber = IN[1]
LoadCaseLabel = IN[2]
application = RobotApplicationClass()
project = application.Project
structure = project.Structure
labels = structure.Labels
loads = structure.Cases
#output
Caseeigengewicht = structure.Cases.CreateSimple(LoadCaseNumber,LoadCaseName,IRobotCaseNature.I_CN_PERMANENT,IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
Caseeigengewicht.Records.New(IRobotLoadRecordType.I_LRT_DEAD)
LoadRecord = Caseeigengewicht.Records.Get(1)
LoadRecord.SetValue(IRobotDeadRecordValues.I_DRV_Z,-1)
LoadRecord.SetValue(IRobotDeadRecordValues.I_DRV_ENTIRE_STRUCTURE,True)
OUT = LoadCaseNumber
This is the error i get when i add "IRobotSimpleCase.label"
This is what i have added in the code.
import clr
#output
Caseeigengewicht = structure.Cases.CreateSimple(LoadCaseNumber,LoadCaseName,IRobotCaseNature.I_CN_PERMANENT,IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR,IRobotSimpleCase.label(LoadCaseLabel))
Can some one tell me what i should change to set the label for the loadcase.
I have added both dynamo files.
Thanks in advance,
Gr Edward.
