Import forces from CSV file into loads table
I have a CSV file with around 27000 value of body forces to be added into a model.
Of course, it's not a good idea to enter one by one.
Is there any way to import (load all of these values) to the loads table?
PS: these values will be body force as shown in the sample attached
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Please check this post.
Rafal Gaweda
Even this method it stills need to format the loads in the excel sheet to be added to the model, but it works.
Hope will Autodesk will add plugin or tool for importing data into the models.
Thanks a lot
