i have a problem in RSA
haitam_bahroune
haitam_bahroune
hello everyone, i have this problem in RSA 2025, i have the educational version, once i install it and start, i click new file the program stops responding. i tried too many ways but the problem never goes. i tried reinstalling it but nothing helped.
if someone can help me with that i would be so happy.
Thank yu everyone.
WALIDGIO
It work fine for me,
try other solution rather than re install it
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @haitam_bahroune
Check if the following forder was created and if it is not empy should have size about 138 Mb).
C:\ProgramData\Autodesk\Structural\Common Data\2025
It should consist of the following subfolders (Data, Plo, Rgl). If it was not created use shared zipped file to create it.
Krzysztof Wasik
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @haitam_bahroune
You can find 2025.,zip file with databases as attachement (I have mentioned in previous reply) in  the following article.
Robot Structural Analysis crashes or freezes when started directly after it had been installed or af...
Krzysztof Wasik
haitam_bahroune
HI @Krzysztof_Wasik
Thank you soo much, i found out that this folder is not created after installation, so i copied it for the Zipped file and i RSA worked smoothly.
Thank again, have a great day.
