Select the bar you want , goto Results/Detailed analysis
Then on the detailed analysis dialog window that pops up , select the force you want detailed and the diagram will show up . Goto the "division points" tab , select characterisc points and click on refresh and they will show up on this dialog and also on the table below the diagram.
Same results can be achieved on table format . Just click on division points , characteristic points and refresh
Rafael Medeiros
