How to re-establish connection between Robot 2014 and ASD 2014
aliyuaziz
Message 1 of 8
aliyuaziz
My connection between Robot and ASD suddently stop working. I am being asked to Select Data Source that describes the driver I wish to connect to! I tried to unRegServer and RegServer again to no avail. Kindly help.
Best regards,
Aziz
Replies (7)
Message 2 of 8
I have the same problem here Cat Happy
Message 3 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Do (both of) you have only ASD2014 and RSA 2014 installed or there are newer versions of ASD, RSA, REX or Revit as well?
Artur Kosakowski
Message 4 of 8
aliyuaziz
Dear Artur,
Many thanks for your response. I recently installed BIMware REX Piles 2014 onto the Robot 2014. There is no any other Robot on the system.
Best regards,
Aziz
Message 5 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to register syspaths.dll
  1. Find syspaths.dll (it should be in C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2014)
  2. In CMD unregister by regsvr32 syspaths.dll /u
  3. Register by regsvr32 syspaths.dll
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 6 of 8
Message 7 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Have you started cmd.exe as admin (available under RMB)?
Artur Kosakowski
Message 8 of 8
Thx alot Mr Kosakowki
it works really fine now
