how can i make the nodes more visible...
vanvan11
vanvan11
hello
My question is can I do nodes more visible than the default
I mean with larger red dots or something
and I do not mean to run the numbering because it confuses even more?
I understand that the issue is not so important
but it comes to operating convenience for me personally
thanks in advance
Ivan Georgiev
Rafacascudo
are you having something like this?
http://forums.autodesk.com/t5/robot-structural-analysis/rsa2016-nodes-graphical-problem/m-p/5653166#...
Rafael Medeiros
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you try to edit registry of RAS 2016 and set:
HKEY_CURRENT_USER\Software\Autodesk\Structural\RSA\29.0\Viewer*MSAA-Enable* false
Artur Kosakowski
vanvan11
no no
i just want to make nodes mor bigger red dots for example or something like that
10x again and sorry for delay
Artur.Kosakowski
Autodesk Support
Autodesk Support
In addition to the change in the registry:
1. Rename mview.dll file in System\Exe folder of RSA 2016
2. Unpack and copy the new version of this file there
Artur Kosakowski
Does this new mview.dll really working?
I don't notice any difference.
Artur.Kosakowski
Autodesk Support
Autodesk Support
You need to change the registry as well. The soultion is included in HF4 for RSA 2016
http://knowledge.autodesk.com/support/robot-structural-analysis-products/downloads/caas/downloads/co...
Artur Kosakowski
