How to delete a load from the load table
Stewan.BotesFCDBK
Stewan.BotesFCDBK
Unable to delete load from load table.
The delete function is greyed out when trying to delete loads from table. Delete input from keyboard does not delete the load.
Work around that I have been using is to manually change the loads to 0. This is time consuming. Don't understand why it needs to be so complicated just to delete a load.
DennisVDijk
Hello Stewan,
workaround: select the load that you want to delete, right mouse click, in menu select "cut":
Kind regards,
Dennis van Dijk
Structural engineer
www.ibureaunoordwolde.nl
Rafacascudo
Good workaround by @DennisVDijk .
You can also right click on graphical representation of the load and click on Delete...
A dialog will open up  , mark " for object selection " , and select which nodes , bars , objects , panels , you want the loads deleted from
Rafael Medeiros
