Add joint in a beam
Add joint in a beam
TtnguKXED2
Add joint in a beam
TtnguKXED2
Im new to ROBOT and im supposed to add a joint where the moment is zero. As the joint rotates, if we have a FULLY RIGID joint panel, then everything within the panel will move or in this case rotate together. How do I add a joint here?
Rafacascudo
Check here to see how to exactly find the moment zero coordinates
https://forums.autodesk.com/t5/robot-structural-analysis-forum/how-to-show-analysis-results-along-a-...
Then divide the bar on this new node and set a moment release on the bar that will be supported.
You can also use "compatible nodes" to accomplish the same result with the advantage of having rotations available on both bars.
Rafael Medeiros
