I wonder why Robot give me a higher reinforecemnt (required area) than what it suppose to be.
for example in my slab I have a maximum moment at the span 320 kn.m/m
I am expexting no more than 3000 mm2 /m , however the reinforcement given by robot is double that. even if u remove the option that increase reinforcement for crack and deflection.
any answer?
2- when reinforcing the support area shall I reduce the force around columns? if I dont do that I would get a massive force.
Regards
Solved by Artur.Kosakowski. Go to Solution.
1. As far as I can see the moment is larger and the reinforcement is not that much bigger than what you expected for smaller bending.
2. Yes, I think you should .
can u see the attached picture please..
why do I need 6196 mm 2 for this area according to a 315 kn.m/m?
my calcs shows half of this value.
Have you included in your calculations the stress limit which is checked when you enter SLS combination in the list?
BASED ON what I can understand from reading .. I need to disable SLS whic is ok and replace the 280 fy by 500 how can I do that?
You need to enter combinations in ULS field only (see the picture I attached to my first answer) and you already set fy 500 MPa.
