Generate the wind loads on multistory buildings by using (ASCE7-02)
Refaat
Advisor Advisor
Message 1 of 12
Refaat
-  Is there any possibility to generate the wind loads for multistory concrete buildings by (ROBOT ARSApor  2013) or not . if possible please help me by steps how can I generate it ?
-   In the attached capture form (CBSpor 2013 ) , I have noted that there is no importance factor. Pls explain ?
Refaat
Replies (11)
Message 2 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Only for 2D frame structure, code ASCE 7-05
Rafal Gaweda
Message 3 of 12
Refaat
May i know , in which cases shall we use (Wind loads on cylinders) ? ? Thanks Refaat
Message 4 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
on Prism object or Cylinder.
NV french code.
Rafal Gaweda
Message 5 of 12
Refaat
How can we?generate wind loads on (3D model)( Concrete mulitstory building) using ROBOT according to ASCE7-05? ? Thanks
Message 6 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
This code is not imlpemented for 3D generator.
Rafal Gaweda
Message 7 of 12
gustavo_c_vasconcellos
Rafal, is there any code to multistory building?
Gustavo
Message 8 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
French NV code.
Rafal Gaweda
Message 9 of 12
Thank you.
Gustavo
Message 10 of 12
Refaat
Thanks alot
Refaat
Message 11 of 12
Mohammed_Ata
How can i define these parameters ?
these method gives the wind force on each story ?
Message 12 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
