formulas used in calculation
Hello everyone,
First of all I would like to thank all stuff for all help you give here on forum.
Now my question is;
Is there any way to check which formulas are used in Robot analysis calculations? There is indeed a reference on the right side, however in case of the lack of the access to the resource I basically cannot compare results with my hand calculations. In this particular case the issue was related with formula for critical moment in buckling. I can't find how the value was calculated. However, my question is general since access to used formulas will be helpful in further works with program.
Thanks in advance!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Please check post 2 from https://forums.autodesk.com/t5/robot-structural-analysis-forum/critical-moment/m-p/3335273
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Tuplaturpo
Community Visitor
Community Visitor
Hello! these links above doesn't work anymore? I have similar problem as the owner of this thread. I want to know how are these three stresses calculated in robot:
where is the section referring? Can't find it on the eurocode 5 ...
BR,
Nikolas
