flexible diaghram
4 REPLIES 4
646 Views, 4 Replies
flexible diaghram
i have applied flexible diaghram with no fe to all floor panels instead of Shell  after that i get to many instability type 1 problems and beams and columns take to much moments and axial force, im talking about like 1000000000 knm and so on for a beam when it should take 1200 knm. What could be the problem and how to solve this?
4 REPLIES 4
Artur.Kosakowski
Lack of bracing  for a model with pinned supports?
Artur Kosakowski
in reply to: Artur.Kosakowski
i can send you model so you can take a look at it
plenty of errors and to many instability types i dont know what cause this because when i have Shell on slabs the instability type 1 dont appear and i dont get so big diffenrences in moments and axial forces..
Artur.Kosakowski
When you don't have surface elements and diaphragms are intended for lateral stiffness (UX UY rigid links used) you cannot place a column on a floor as there is nothing to prevent its vertical movement. You have to have either a wall or a column or a beam directly under it.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
