Hi, I was wondering if anyone could help me, I am currently modelling a precast stair core in Robot and was wondering when I model a stair flight as a diagonal slab, is this load taken as a projected load for the self weight of the stair flight concrete slab? I have modelled in the dead weight of the risers separately and have now changed them to a projected load, however is the self weight of the slab itself taken as a projected load? or do I need to define this in the load definition? I have attached screencast link below hopefully it works. your help on this would be appreciated!
Solved by Artur.Kosakowski. Go to Solution.
The self weight by default acts in the vertical (-Z) direction and is the function of the panel area, its thickness and the density of a material assigned to it. In other words it is not projected and IMHO should not be.
Thanks for the reply, when you talk about the -Z direction, is that in the global orientation or local panel orientation? I.e, if a stair flight is on a slope, the local panel z axis is in the diagonal direction?
It is in the global direction. You can decide on X+/X-/Y+/Y-/Z+/Z- where the last is the default self weight direction.
