We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Find erro Separate structure
Message 1 of 13
Hi all.
I is prolem erro Separate structure.
I can not find the error "Separate structure"
Is there a way to find it?????
D
Capture.PNGin my model
Replies (12)
Message 2 of 13
Let the analysis run through.  Check the deflected shape.  You will see it pretty quickly.
Message 3 of 13
Rafal.Gaweda
Autodesk Support
Autodesk Support
After calculations select nodal group $SUB...$
Rafal Gaweda
Message 4 of 13
Thank two you.
Message 5 of 13
After I find the nods we should eliminate them?
Regards
Mário
Message 6 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
You should look at the elements they belong to and check why they are separated from the rest of a model (assuming this is not intentional).
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 7 of 13
I check all the structure, and all is connected.
Now the error disapear but the deflection is bigger than expected.
Regards
Mário
Message 8 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm sorry but I neither know the assumptions you made to estimate the deflection (of a beam, slab, for static analysis, design module ? ) nor any knowledge of your model.
Artur Kosakowski
Message 9 of 13
This is my model. Can you help me?
Regards
Mário
Message 10 of 13
Message 11 of 13
Rafacascudo
You have to check your model  especially where you have a not ortogonal Panel beam (number 25 )
Some bars are not connected to this panel and also the column panels are not conected to it (panel 25).
Rafael Medeiros
Message 12 of 13
Hi
I am doing a structural analysis of an individual steel module which is used for modular building project. I modeled this module with all its elements (floor and ceiling joists, wall studs etc.), applied loads in Revit structure 2016 and exported it to Robot structure analysis for structural analysis purpose. But during the analysis, it gave me some warning as shown in attached pictures. I also attached the robot file. It is really appreciates if you can help me. I want to delete these warnings but I do not know what I should do. Thanks in advance
Message 13 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please check post 11 from http://forums.autodesk.com/t5/robot-structural-analysis/instability-type-3/m-p/6475461
In addition please do not post the same issues in multiple topics on the forum as it may cause many people looking at the same problem separately rather than being able to see what others have already managed to find out. Thank you for your understanding.
Artur Kosakowski
