Hi
I am just curios to what the best workflow is regarding the generation of the calculation model.
Let say I do a initial calculation where I generate the calculation model.
- Later, I add some elements such as beams and panels. Do I now need to generate the calculation model again?
- At a later point again I add some loads. Do I now need to generate the calculation model again?
I have read the following post: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Generation-of-Computation-Model/m-p/3362625/...
Regarding workflow;
Let say I am satisfied with the mesh I have currently obtained for my panel. Is it any way I can keep this mesh even if I run generation of calculation model (freeze command for instance)?
In advance, thanks.
Regards
Peder
