Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Extrude solid profile
Message 1 of 29
Hi friends!
Is it possible to draw, for example, an L-shaped section and then extrude it as a solid? How?
Please check the attached file for the intended result.
And if so, can i aplly a material to it and study it´s stresses, deformations, etc...
Many thanks.
Accepted solutions (4)
Replies (28)
Message 2 of 29
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 3 of 29
That was tremendous!
Many thanks Rafal!!!!
Message 4 of 29
Rafal, sorry to bother again, but after i saw your video i went to try and do it myself.
But when i choose panel, i dont have the "face" option. Only "panel" and "opening".
Its in portuguese, sorry.
Message 5 of 29
Rafacascudo
structure type should be Solid (volumetric.)
Rafael Medeiros
Message 6 of 29
That´s it!
I´m such a noobster!
Message 7 of 29
Rafacascudo
É normal no começo!!!Smiley Wink
Rafael Medeiros
Message 8 of 29
Português!!! 🙂
Sou eng civil e tenho usado um programa da concorrência. Estou num período de trial 30 dias e tudo me leva a crer que vou trocar para o Robot.
Abraço!
PS: (Just not to be rude, i typed in portuguese that i am on a 30-day free trial of Robot but i´m loving it. I will trade the current software i use for Robot! ) 🙂
The only thing that i still can´t figure how to do is this: http://forums.autodesk.com/t5/robot-structural-analysis/modeling-aluminium-window/td-p/5588995
But i´ll get there... eventually... 🙂
Message 9 of 29
Hello guys.
Here I am with another doubt.
I want to apply an uniform load on this surface (-y direction) but i can only select the edges. Can´t figure how to select the solid surfaces to apply loads.
Once again, thanks for the help.
Message 10 of 29
Rafacascudo
Do you really need to use solids?? Why don´t you use a shell model. It´s a lot easier to model , apply loads and get/read results!!!!
Rafael Medeiros
Message 11 of 29
I use shell models to study, for example, glass panels and concrete slabs.
When i need to study an isolated profile (like the L shaped one) can i also use shell models?
I tried that before i posted this topic  but i could only get a mesh in the contour of the "L". It was modeled like a hollow section and could not even define its material.
If this can be done with a shell, can you kindly tell me how?
Many thanks!
Message 12 of 29
Rafacascudo
One of the methods for creating a L shape shell model.
http://screencast.com/t/sbj6sRwiO2
You can also use extrusion like you did for solids , or create contours and set them to be a panel
Rafael Medeiros
Message 13 of 29
Excellent!
On the first method you defined the bars section as "cabo 2x14.8".
As we are only studing the shell, the bars section does not matter, right?
This forum is proving to be much better than all of the tutorials i´ve found so far.
Thanks again!
Message 14 of 29
Rafacascudo
Yes , it could be any bar section , it doesn´t matter .
I used them just to easily create the 2 plates contour. After that ,don´t forget to delete all bars !!!!
Rafael Medeiros
Message 15 of 29
Already tried and worked wonders Rafacascudo!
Now, (and this will be my last question, i promise), can i simulate the effect of bolts on one side of the profile?
Please see attached picture. It´s one simulation i did on another software.
Once again, terrific support you gave me. 🙂
Message 16 of 29
Rafacascudo
Something like this??
http://screencast.com/t/44toQIcGV
Rafael Medeiros
Message 17 of 29
EXACTLY like that!!!
Many thanks rafcascudo! Smiley Very Happy
Message 18 of 29
Hello rafacascudo,
After all your (precious) help I run the calculations and, along the way, something must have gone very wrong due to some configuration that i missed...
I attach the file and a print screen of the results in case you can check it and find what poor miufs has done wrong this time. 🙂
Message 19 of 29
Rafal.Gaweda
Autodesk Support
Autodesk Support
Are you sure about loads ?
Rafal Gaweda
Message 20 of 29
Hello Rafal.
Where do you checked that table?
I have this table:
The load on PZ is not defined as 4 kN/m2??
Many thanks!
