Error 5000
Error 5000
Error 5000
I have posted in the below, but no one replied. Can support please help?
https://forums.autodesk.com/t5/robot-structural-analysis/incorrect-data-error-nr-5000/td-p/3311505/p...
Rafal.Gaweda
Autodesk Support
Autodesk Support
Supports on roof nodes block UX UY modes.
Besides, your sw mass is doubled - mark Disregard Density in Modal case definiton (or delete case 1 from load to mass conversion)
Solution 1:
Replace supports by the ones shown below . Then you will need only 8 modes to get 90% of mass participation
or leave them as they are and then diaphragm should have a mesh or should be ordinary shell panel.
Rafal Gaweda
I am getting this error again.
Everything was working fine. I was only refining member sizes. Can you please advise. I have attached the model.
Rafal.Gaweda
Autodesk Support
Autodesk Support
