- Mute
- Permalink
- Report
I have been applying wind loads and cladding loads in Robot. Originally I had applied these as linear load on edges but when transferring between robot to Revit found the loads were not recognised.
I then proceeded to delete these loads and reapply them using the linear load 2p type. These have been transferred between robot and revit however now when running the analysis I get an error 2110 and no results. When clicking on the error in the relevant load case I can see it highlights all the reapplied loads that I entered using linear load 2p.
PLease can you help correct my model so the loads can be applied. There are lots of loads added this way so a method that can correct them all collectively would be ideal. I also want the model to be able to be transferred between robot and revit.
I did try and upload the file but it is too large and it wont let me do it - 20mb big.
Your help would be much appreciated.
Regards
Eddy Battman
