Empty steel design results table for South African Design code
5 REPLIES 5
340 Views, 5 Replies
Hi. Has anyone been able to use the Member verification or Group Design option with the South African codes? As far as i can see it doesn't work? If someone could verify this it would be nice. Thanks very much.
5 REPLIES 5
Artur.Kosakowski
Hi @Anonymous
Could you give us more details on what doesn't work exactly?
Artur Kosakowski
in reply to: Artur.Kosakowski
Hi
When i run the verification on the standard setting which i think is set to British standard, it gives me results as indicated below.
Standard CodeStandard Code
Then i change the Design code to South African, then the results table opens but no results as below.
South African CodesSouth African CodesNoting in the TableNoting in the Table
Artur.Kosakowski
Hi @Anonymous
Could you attach the SA version of the model?
Artur Kosakowski
Hi @Anonymous,
When you change the design code in Job Preferences, you must redefine the code parameters of elements - "Member type".
I hope I have helped.
Yip, That did the trick.
Thanks very much
