Empty element list in load table edition and load text edition tabs
Message 1 of 11
Hello, I have been working on one project. Created it in Robod from zero.
I have been editing some load values ant element list, saved the file and then noticed that most of the list values in "list" tab, was empty. However I can see all loads added to the correct bars and nodes in "view" mode. Calculation result also seems correct.
The problem is, that if I will need to edit loads in the future it will be very hard to find which row is for which elements.
How can I fix that?
P.S. See attached image
Replies (10)
Message 2 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
The empty lit records might have been created after you divided bars. You can delete them in the way illustrated on the attached picture. In addition you can select these loads graphically and edit them using their properties under the RMB.
Artur Kosakowski
Message 3 of 11
No, I didn't divide bars.
I remembered what I did: Then You open "load" window and change load case in the upper menu, all bars automatically are selected, I deselected all bars by clicking on an ampty spot in view window.
There are some not empty spaces in list column. As you can see when I open load window, there are selected just 14 and 56 bars - in wind cases (which I edited last time) just they are corectly showed in a list column.
I think I need somehow to make robot show all bars again then I open load section
by the way - waht is RMB ?
EDITED: They are not empty loads - they are OK, just the member numbers are showed as "empty"
Message 4 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Right Mouse Button
Artur Kosakowski
Message 5 of 11
Oh 🙂
They are not "empty" loads, even if I clck it nothing happens...
Conversion to Excel shows the same table, without most of element list..
Any ideas?
Message 6 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Attach the model please.
Artur Kosakowski
Message 7 of 11
Could You write your e-mail please? (for example in a private message)
I can't spread the model widely
Message 8 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Use one of these sites:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Sending-bigger-files/td-p/3795062
and send me the link to the file in the private message.
Artur Kosakowski
Message 9 of 11
Sent. Check your inbox, please
Message 10 of 11
PaulGrimes2282
I've had this problem too - assumed it was a bug. opening in repair mode repopulated the table.
hope that helps!
Message 11 of 11
Thank you all for help and quick response 🙂
