Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
elements disappear
15 REPLIES 15
Message 1 of 16
649 Views, 15 Replies
elements disappear
15 REPLIES 15
Message 2 of 16
Artur.Kosakowski
You cannot move a bar without moving its end nodes (which has to be selected first). In other words you should select end nodes of the beam to move the beam (beam doesn't have to be selected) but moving these nodes will result in moving top ends of the columns too. To sum up the copy and delete (as you did at the end of the movie) is the best option.
Artur Kosakowski
Message 3 of 16
in reply to: Artur.Kosakowski
Thanks for the reply,
but I disagree. The shifting technique shown, in which you select the element and not the nodes, is present in many programs and is very useful to move the element but not the nodes connected to other elements.
The function should also be present in the robot, and, in fact, it works with other files.
https://www.dropbox.com/s/r5l88h2l1fee5n6/ElementoNOdesaparecen.mp4?dl=0
I'm waiting clarification.
Thank you,
Daniel
Message 4 of 16
Artur.Kosakowski
Could you attach the model from the first movie please?
Artur Kosakowski
Message 5 of 16
I attach the file and another video.
I realized that the problem is highlighted by selecting the moving vector through the nodes.
https://www.dropbox.com/s/xim972mg9qesq1r/searchingTheBug.mp4?dl=0
https://www.dropbox.com/s/cnvdxnteois47mg/ElementosDesaparecen.RTD?dl=0
Message 6 of 16
Rafacascudo
nothing disappears here
Try to find where did the missing bar(54) go. Does it vanish also from the bar table??
Rafael Medeiros
Message 7 of 16
in reply to: Rafacascudo
So strange. It happens to me as shown in the video.
I await the response of Autodesk that is supposed to be considering the bug.
Thank you,
Daniel
Che strano. A me succede quanto mostrato nel video.
Rimango in attesa della risposta di Autodesk che si suppone stia valutando il bug.
Grazie,
Daniel
Message 8 of 16
Artur.Kosakowski
Hi Daniel,
As for Rafael I can't see uissie as in my case a bar is correctly moved to a new location. What I noticed is that in the movie you used different file then the one you provided the link to. Could you check as suggested by Rafael if you have the same number of Bars in the bar table before and after moving the selected bar please? Do you have the same issue when you start a new project with a single bar and you move it or is it for a specific model only?
Artur Kosakowski
Message 9 of 16
Good morning,
Perhaps this video can help to isolate the problem.
https://www.dropbox.com/s/mih2uf20ov3qf9h/ElementosDesaparecen2.mp4?dl=0
I attach the files with which I filmed the video.
For the moment, the problem is evident only with the attached file.
Good day,
Daniel
Message 10 of 16
Artur.Kosakowski
Thank you Daniel. The file you sent allowed me to reproduce this issue which is now being investigated by the development team.
Artur Kosakowski
Message 11 of 16
Thank you Artur
Message 12 of 16
Artur.Kosakowski
Corrected in SP4 for RSA2016.
Artur Kosakowski
Message 13 of 16
Thaks.
I don't find the SP4
Message 14 of 16
Rafacascudo
Is there a direct link to it?
Application manager also doesn´t find it .
Rafael Medeiros
Message 15 of 16
The direct link will be available soon (after the upload process has been done). For now you should be able to download if from the Application Manager (I have checked that it finds it installing it myself Smiley Happy
Artur Kosakowski
Message 16 of 16
Doesn´t show up here.
I´ll wait for the direct link...Smiley Frustrated
Rafael Medeiros
