Hi there
I'm new to RSA.
I did insert an example to understand how the model works.
I imported a revit model to robot.
I got the error " element geometry is not supported by the module" many times although i used column sections more than the minimum in the code.
Column size in this case is 20 x 60 ( in cm )
Tell me please the rules to avoid the " element geometry is not supported by the module" warning.
Solved by Artur.Kosakowski. Go to Solution.
Hi @Anonymous
The column dimensions cannot be smaller than 20.4 cm.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
