Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
element geometry is not supported by the module
2 REPLIES 2
389 Views, 2 Replies
Hi there
I'm new to RSA.
I did insert an example to understand how the model works.
I imported a revit model to robot.
I got the error " element geometry is not supported by the module" many times although i used column sections more than the minimum in the code.
Column size in this case is 20 x 60 ( in cm )
Tell me please the rules to avoid the " element geometry is not supported by the module" warning.
2 REPLIES 2
Artur.Kosakowski
Hi @Anonymous
The column dimensions cannot be smaller than 20.4 cm.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
in reply to: Artur.Kosakowski
Thanks man.
You are a legend.
